Key fob issues
Key fob issues
Well, both key fobs for my '08 HHR Panel finally crapped out and wouldn't unlock the doors. Seems that all the buttons were getting unreliable except the panic alarm button which is the one I used the least. I contacted the dealer and learned that a new one would cost me $155.oo plus $55.oo to program it!! Talk about robbery without a gun.
So here's what I did. I opened up the fob and cleaned all the contacts with alcohol but that didn't work. Wondering how a rubber button completed an electrical circuit, I figured it must have been impregnated with a metallic coating that may have worn off hence the one I used least was still good. Built to wear out, eh? So I cut a tiny pieces of aluminum foil and glued them over the the problematic little buttons and bang, they all work like a charm. "Whooped 'em again didn't we Josey." FTF I say!
or you can purchase the rubber/silicone pad inserts on ebay etc. (which doesn't need any reprogramming), or do it the hard way, like I did, by shaving off the carbon buttons off an old tv remote/calculator and using silicone adhesive to glue them on your old insert.
I'll try the aluminum foil trick one of these days.
Yep, could have bought a used one on ebay and hoped it worked.Then would had to program it. Could have tried to find the rubber insert that worked with the electric side doors in my panel. But, seeing as I had the tinfoil from the sandwich I ate the fix didn't cost me a dime!
I hope you had a great weekend.
