Key fob replacement and functions
Hi, my keyfob is not functioning,red horn button works, unlock also. Locking the car is not functioning. I changed the key fob internals with the spare keyfob, same problem. Put some tin aluminum foil and glued some tiny pieces on the inside of rubber pad to make better contact. Are both fobs damaged or is the car not receiving a signal ? I need the key fob lock and unlock buttons to do the tpms relearning procedure.
