key removal issue
Old 08-11-2009 | 08:01 PM
Izzy's Avatar
key removal issue
My '07 HHR won't let me turn the key all the way off to the lock position or remove the key. Is this a common problem, and is it an easy fix? I'm pretty sure it has something to do with the shifter, because I can also shift into any gear while the var is off. Any help out there? Thanks, Izzy
Old 08-11-2009 | 08:04 PM
NxlKing2304's Avatar
try rocking the shift knob up and down while in park. Also make sure nothing is in the way of the shifter! That happened to me! This has been an issue though. Use the Search function to find out more.
Old 08-11-2009 | 08:05 PM
you should definately not be able to shift at random, the system id designed to work only when brake is applied to shift out of park.
Old 08-11-2009 | 08:11 PM
Izzy's Avatar
Thanks!, I've tried shifting it into gear then back into park, but that didn't work, I'll give the up and down motion a try.
Old 08-11-2009 | 08:12 PM
Izzy's Avatar
that's what I thought, but it does let me shift while the car is off.
Old 08-11-2009 | 08:28 PM
If the car is on and you press the brake pedal, can you hear a clicking sound from the shifter area? If you don'y hear that I would check a fuse maybe that powers that, maybe it's blown. also there maybe a problem with the shifter solenoid
Old 08-11-2009 | 08:33 PM
DLVRNIT's Avatar
Were you able to get the key out? There is a section in the owners manual about a release lever under the steering column!
Old 08-12-2009 | 06:44 AM
pitbull76's Avatar
It's a common problem. The shifter needs to be replaced.
Old 08-12-2009 | 07:02 AM
Old Lar's Avatar
There were some problems with the key stuck in the ignition. Mine was repaired by the dealer under warrenty.
Old 08-12-2009 | 08:32 AM
GRUMPEE's Avatar
Ditto, I had mine replaced under warranty 7 months after I brought her home
Quick Reply: key removal issue
