Keyfob remote will lock but won't unlock
Old 09-13-2015 | 11:28 PM
Lucky's Avatar
Originally Posted by bugo
I touched the contacts to a metal object and the doors unlocked, so hopefully the new rubber buttons will fix the issue.
That will fix it. You can use a little contact cleaner an clean the metal contacts then it will be all ready for the new pad.
Old 09-14-2015 | 04:55 AM
bugo's Avatar
What kind of contact cleaner? What are some brands? Can you get it at the parts store? I bought some contact cleaner to clean out the switch on my Telecaster a few years ago. Maybe I can use it.
Old 09-14-2015 | 06:07 AM
You could use rubbing alcohol.
Old 04-17-2019 | 07:11 AM
Alexis Red's Avatar
1 button not working on my key fob
I got a 2010 HHR 2.2/slushbox today. Both keyfobs will lock the doors and set the alarm off, but neither will unlock them. The batteries were recently replaced. I did some online searching and I couldn't find a solution. Help!
I had 1 button on my key fob that didn't work, I put a piece of aluminum foil under that button. It works, now. I know I'm late to this discussion, but if it helps anyone else with this same issue, good deal.
Old 04-17-2019 | 10:23 AM
Welcome - hope you find some good info and help here.
Yeah, that tip about the tin foil was also mentioned in post no. 2 above back in 2015 - but like they said, it's temporary at best. Now that replacement cases and button replacements are available at very low cost, they are a longer lasting solution.
Old 04-17-2019 | 12:59 PM
I have 2 wall mounted remote controlled ceiling fan switches that I repaired the same way 5 years ago. The foil from a cigarette pack used to work.
sky
03-22-2018 10:44 PM
Glanden
09-23-2015 06:18 PM
Finch106
06-06-2012 09:48 AM
undentu
01-20-2012 06:36 PM
HHR_SS_QC
04-07-2009 09:46 AM
Quick Reply: Keyfob remote will lock but won't unlock
