Leakage past exhaust valve
Old 01-19-2018 | 12:08 PM
Treep's Avatar
I have been having a misfire problem with my Chevy HHR 2007 so I took it to the dealer and I have 50 psi & 60% leakage past exhaust valve in cylinder 1 according to dealer with $2500 to $3200 repair cost. just went over a hundred thousand miles.
Old 01-19-2018 | 12:16 PM
aradmahogany's Avatar
What sort of problems? Like only a misfire or anything else going on with it?
Old 01-19-2018 | 12:21 PM
Treep's Avatar
When I am at idle usually below 2000 RPM it sets off the TC warning signal and shifts hard between 1st and 2nd. Other than that I don't notice anything. Codes i get are p0301 & p0301pd
Old 01-19-2018 | 12:36 PM
Treep's Avatar
Not that I know of but it seems like there's some oil around outside oil
filter area
Old 01-19-2018 | 01:10 PM
Treep - how about we keep all the threads about this problem in the same thread, rather than opening another
I've merged your threads and moved them to the proper section - ie: Problems/Service/Repairs
Old 01-19-2018 | 01:11 PM
Yes, you need a valve job, the quote probably is for a ne head assembly. Read the quote you were given.
Please stop double posting.
Old 01-19-2018 | 02:29 PM
Treep's Avatar
Sorry pretty new to this. Didn't mean to double post but thank you
Old 01-19-2018 | 02:38 PM
Depending on engine new head approx.
labor 2.2L=6 hours 2.4L=9 hours
head 2.2L=$720 2.4L=$632
Old 01-20-2018 | 08:09 AM
They said P0301.
Old 01-20-2018 | 09:13 AM
There could be other causes. From my own HHR experience with a leak down test, the loudest sound isn't necessarily the worst leak.
https://www.chevyhhr.net/forums/ss-s...e2/#post795044
https://www.chevyhhr.net/forums/how-...84/#post796543 (step 22)
Quick Reply: Leakage past exhaust valve
