Leaking wiper fluid
Old 08-13-2013 | 05:27 PM
DuncanJ's Avatar
Leaking wiper fluid
I have a 2011 1LT with 50618 miles. The reservoir will not hold fluid. As soon as pour it in, I get a steady stream down on the garage floor. Has anyone had this repair done at the dealer and should it be covered under warranty ?
Old 08-13-2013 | 05:38 PM
Fox Hat's Avatar
This Sounds like a job for WARRANTY MAN.!!!!
Old 08-13-2013 | 06:13 PM
You can pull the reservoir to see if the pump is loose, some folks have had leaks occur that way.
Also check the hoses, one may have popped off.
If the tank itself has cracked, call your dealer.
Old 08-13-2013 | 06:15 PM
It is the washer pump has gone bad. Check with your dealer if you are still under the bumper to bumper. The good news is the pump is incredibly easy to install yourself and is available on Ebay for about $30 search phrase "HHR washer pump". No tools required, but may be handy, it's only held in by an O-ring.
Expect it to happen every couple of winters especially if you don't use "winter fluid".
Old 08-13-2013 | 07:50 PM
Due to the mileage of your vehicle you are out of bumper to bumper warranty. I can check to see if there's a recall or TSB dealing with your concern on your vehicle. All I would need for that is your vehicle identification number. Once I have that information we can take the steps forward to get this resolved.
Jessica L.
Chevrolet Customer Care
Old 08-14-2013 | 07:04 PM
jbman's Avatar
If its leaking you could seal it with a product called Seal All great stuff used it years ago
J W Davis
02-18-2020 07:59 AM
bad03xtreme
Maintenance and Upkeep
13
12-19-2014 06:23 PM
phenderson51
01-21-2014 02:46 PM
GDZHHR
05-23-2006 06:31 AM
Quick Reply: Leaking wiper fluid
