Leaky Left Front Sunroof Drain
Old 02-24-2019, 05:10 PM
spacer's Avatar
Thread necro!
Butyl patch affects the passenger side.
After a few days of flooding, heavy rain, Herman has a soaked driver's side carpet, squishy wet in front, and damp in the back. Firewall and the carpet foam are dry above foot level, but I soaked out half a gallon of water from the floor under the carpet.
I currently have the carpet propped up, and a big fan angled down toward it. Between that and the now dry outside air, I'm hoping to have it dry by dark... or at least less damp.
I do suspect the sunroof, as I know it has a small leak. I've been relying on the drain to keep bad things from happening, as I'm not sure the car is worth what a sunroof repair would cost. I've done some wrenching, but I'm no mechanic.
There is a wear spot with a tear on the lower weatherstrip, too. I'm not sure whether that would be enough to cause the amount of water I found, but I'm pretty sure I can handle replacing that just fine.
I'll try some weed whacker line to check the sunroof drain, too.
No more sunroofs for me.
spacer is offline
Old 02-24-2019, 05:34 PM
Sunroof’s are fine, they do require maintenance, like flushing the dirt out of the tracks and drains
Oldblue is offline
Old 02-24-2019, 05:45 PM
spacer's Avatar
I suppose. I'm just venting some frustration. I still have a list of things I need to do, and this just adds to it.
Nature of the beast, I suppose.
spacer is offline
Old 02-24-2019, 06:20 PM
That’s hot rodding, if your car project is finished, you just sold the car!!
Oldblue is offline
chrissgee
12-09-2018 09:35 AM
ricky2009
08-11-2013 12:58 AM
GhostSoldier62
Maintenance and Upkeep
07-22-2013 05:59 PM
Quick Reply: Leaky Left Front Sunroof Drain
