Lift Gate Re & Re ?
Lift Gate Re & Re ?
I did a search and came up empty for an lift gate change or removal. I was wondering how the wiring to the gate disconnects? Is there a main plug, or will I need to remove and fish the wires through the gate for the light and release?
So far so good, the only snags so far, are the plug that goes to the release handle to open the gate, needs to be dismantled. It will not fit through the opening while still assemed, it was fairly straight forward to pull the pins to slide the plastic clasp off though. The other hiccup I had was when I unplugged the harness at the wiper motor the release handle didn't work, I'm assuming there's either a ground or the circuit is interrupted at the lights or wiper. I had to go so I just plugged it back in to close the gate until I'm ready to remove the other one too.
When I'm done, I'll try to assemble a step by step, for others in the future.
HHR lift gate removal
