losing air in tires
losing air in tires
put two new tires on horatio and I have had 4 flats in 4 days on the same two wheels the rims are true no dents. Is it possible that the tpms units are leaking? installed new shcrader valves at my witts end please help
when doing the soapy water test on tire machine no leaks but after putting wheels on car they are flat with a couple of hours. Drove home no problems but went flat quickly when backing into spot. Wife was ready to nuke the car. thanks for clearing this up.
Thats the Right answer but .....
Back in the good old day's we used to have a tire test tank full of water.
To check for leaks you get to put the complete assemby under water about a half at a time.
We would pump the tire up to Full Recommended pressure first.
We did not use soaps because in a tank it would be impossible to see a leak with all the suds created just by putting the assembly in the tank.
It was a sure fire method before all this high and mighty stuff we have now.
SF
My guess would be they are leaking @ the beads.
They may not have seated properly or they may have been damaged by the installer or they may have had defective beads or improper tolerances to begin with.
You don't mention what Brand you put on ???
Bottom line ... Take them back before you damage them from low air pressure and create another problem in getting them replaced.
NOW !!!!!
SF
tpms units had aluminum stems that were torqued correctly but with the temps being single digits the stems and the steel wheels expanded and contracted at different rates. Put rubber ones and so far so good. thanks again for all the help.
