low tires?
Probably the valve stems that are leaking. Insist that the dealer replace all four valve stems under warranty and I bet that stops the problem. If dealer refuses, it is not all that expensive of a procedure for a tire shop to do, and they can installed an upgraded stem that might be of higher quality anyhow.
thanks for all the great answers... i didnt think to check since before we left the dealer (yes it was a used car purchase) they took it to make ready, filled it up and washed it and supposedly checked everything... like i said as soon as i can we will send these tires to the tile shops and get some new ones, i see discount has kumhos and another weird sounding brand pretty cheap sooo.... anyways thanks again, just wanted to see if i needed to lok forward to the constant worry like we did with the pt...
