Major electrical problems after ignition replaced
Old 11-04-2017 | 09:06 AM
I am not going to try to read your OP again, it hurts my eyes.
What is your exact problem at this time?
Old 11-04-2017 | 09:10 AM
Get a used BCM , they are available coded to your VIN on Ebay
Old 11-04-2017 | 08:44 PM
v2in's Avatar
Ok, here goes. Start the car, rear wiper is on. Touch off button for rear wiper, shuts off car. Turn off ignition, remove key, I hear a click. Restart car, rear wiper is on. Try to operate windshield wipers, car shuts off. Repeat restart procedure (rear wiper on again, leave it alone). Try to operate AC, condenser kicks on, no fan. Replaced resistor and tested fan and fuses. No AC. I have no lights on the front of the car at all. No turn signals, head lights or spots (in bumper). Rear lights all work. Radio is intermittent and dash lights go haywire. I have a very unique automobile. It's hurting my brain and my wallet.
Old 11-04-2017 | 08:45 PM
v2in's Avatar
I was looking on Ebay but not sure how it would work. I'll contact one of them and see what we can do. Thanks.
Old 11-04-2017 | 09:31 PM
Again, all those systems are fused under the hood, I wouldn't be thinking that the BCM is suspect.
Old 11-04-2017 | 09:54 PM
Cherck your PM.
Going by the thread title; All of this started immediately after the ignition recall was done? Then it is not your problem.
It sounds like some wires got crossed. The only thing all of those things seems to have in common is the run relay. Has anyone messed with the car since you had it? Any enemies?
The ignition switch is not really a switch; it is a key position sensor.
If these 2 wires somehow got reversed weird things could happen. The blk/wht wire is 5vRef and the wht wire is a signal to the BCM. Note the resistor in the switch.
Most "experts" in auto electric would assUme one is +12v and the other in Ground.
BigDuke14
03-04-2015 06:13 AM
firemangeorge
GM Recall Campaigns
15
08-01-2014 07:22 AM
JimDaddyo
GM Recall Campaigns
28
06-05-2014 01:13 PM
ouhockeyplayer
02-12-2010 01:21 PM
foolmoon_design
02-03-2010 08:12 AM
Quick Reply: Major electrical problems after ignition replaced
