Mechanic in LA/Hollywood
Old 06-27-2020 | 06:05 PM
Squinn's Avatar
Can anyone refer a Mechanic in LA/Hollywood area. My Son’s 05 HHR has Charging system light on. Battery is newer. Had it to Dealer & said it fine. I know there is a trick to replacing the alternator.
Old 06-27-2020 | 06:15 PM
Very easy job. The hardest part is getting the belt on & off, still very easy. Remove some of the plastic expansion anchors, maybe a small screw or two from the right front splash shield. Jack up the right front side of the car, support with Jack stand. Pull back the splash shield a bit. Then refer to post #40 in this thread. https://www.chevyhhr.net/forums/www....page=4&t=31446
Old 06-27-2020 | 06:30 PM
Welcome Squinn
FYI. No 2005 HHR's. 1st year was 2006.
Old 06-27-2020 | 07:41 PM
Welcome to the site, the alternator is fairly easy to replace, as mentioned above
Old 06-27-2020 | 08:34 PM
Squinn's Avatar
My Bad. Bought it for him in 2005
Old 06-27-2020 | 08:36 PM
But first, you should let your auto parts store perform a free battery load test and charging system test.
O7hhr
06-18-2016 09:29 AM
jaminbruce
09-27-2015 07:14 PM
riceman
07-04-2015 06:02 PM
mark1104
07-08-2014 04:57 PM
TDee1970
08-15-2012 04:58 PM
Quick Reply: Mechanic in LA/Hollywood
