Message Gate ajar
Old 12-04-2018 | 03:58 AM
iroga65's Avatar
Message Gate ajar
While in motion, the light "gate ajar" has started coming on occasionally. The liftgate is closed, naturally. Where should I look for the problem in the first place?
Old 12-04-2018 | 08:16 AM
The latch switch.
Old 12-04-2018 | 08:19 AM
Loose wires inside the gate at the latch mechanism
Old 12-08-2018 | 12:16 AM
iroga65's Avatar
Thank you. But I do not quite understand where? Is number 1 or 2?
Old 12-08-2018 | 02:21 AM
Cat Man HHR's Avatar
Check switch #1 pin#6 pink and black wire. Might be a wire issue or possibly the switch is bad
It looks like you will have to remove the liftgate panel to get to it.
Old 12-08-2018 | 08:48 AM
#1 latch
#2 touchpad
Old 12-12-2018 | 11:53 AM
J W Davis's Avatar
Talking Why
Why can a door or a gate be "ajar", BUT a jar can not be a door or gate?
Go figure.
I was asked that by a 5 year old nephew.....
Old 12-12-2018 | 12:11 PM
A moment to ponder!
Old 12-20-2018 | 02:08 AM
iroga65's Avatar
What do you think, if I cut the wire from BSM # 55, the signal disappears?
If it is damaged inside the harness, does the signal appear?
Old 12-20-2018 | 08:34 AM
If you ground that wire the message should go away The "closed " signal needs to be present for the Remote Start to work.
Quick Reply: Message Gate ajar
