Misfire on Cylinder #3
Hey guys, my check in light came on the other day on my 2007 LT. I went to autozone and they said cylinder #3 is misfiring. I heard there was a TSB on the 2007 that this should be covered under the 100k drivetrain warranty. Does that sound accurate? FYI.. it was a rental car and I am the 2nd owner in case that matters. Vehicle has 56k miles.
I heard that some engines had incorrectly installed piston rings, but I can't find the TSB in the list.
https://www.chevyhhr.net/forums/show...ighlight=rings
Anyone know how to make the TSB thread more easily searchable? Currently I have to open each page and search for text in the page.
My 2008 ss had a p0301 and p0303 both misfires aftermarket warranty will not cover mine so I put it in the shop yesterday new head studs performance pistons machined head stage 2 clutch new flywheel green stuff pads and new drilled rotors
If you're out of warranty, you probably have a good case for GM to cover the repairs, due to this being a known issue. See what your dealer will do for you.
