Need heip
Old 06-04-2020 | 08:24 AM
PulpFriction's Avatar
A bad tank of fuel? Did the trouble start after a fill up?
Sadly some old stations have gotten away with not replacing old tanks.
Old 06-14-2020 | 12:16 PM
Bmh2k20's Avatar
Update
Originally Posted by Ron Hanks
I have a 2009 hhr. It starts right up then dies. I'm at wits ends. OK. Here we go. I
changed the fuel pump, plugs, coils, cam sensors, map sensors, o2sensors,
intake manifold. It will stay running if you keep pumping the gas it fluctuates
between 2000 and 5000 rpm. Still throwing codes: p0101, p0171., p0101p,
p0171, and p0300 please help.
Just just to add to this we have since replaced all injectors. Cleared codes and drove, but it still has the intermittent missing and stall.
I am adding attached screenshots of codes, and data from odb hopefully somebody can make heads or tails of it.
Old 06-14-2020 | 01:50 PM
You're adding to the OP? Are you working on Ron's car?
Old 06-14-2020 | 02:52 PM
All of those "not passed" means the computer was cleared and now the computer needs to run all of the OBD tests.
My guess is that you also forgot to plug the MAF back in.
You might check fuse #33 undehood.
Old 06-14-2020 | 03:43 PM
Bmh2k20's Avatar
Yes he's my father and we are working together on this
Old 06-14-2020 | 04:48 PM
Check the MAF sensor connector and report back please.
Old 06-15-2020 | 10:55 AM
Potted palm in the corner.
Old 06-15-2020 | 10:56 AM
Bonez's Avatar
for the misfire.... is the timing correct?
Old 06-15-2020 | 11:52 AM
Doubt it’s timing, more likely fuel pressure or loose coil or injector connector and or MAF sensor isn’t plugged in tightly.
Old 06-15-2020 | 12:57 PM
Ron Hanks's Avatar
Checked the MAF connection all pins are good and plugged in tightly. Checked all connections they are good also
Quick Reply: Need heip
