Need heip
Old 06-15-2020 | 10:31 PM
  #31
Ron Hanks's Avatar
Originally Posted by donbrew
No you didn't, what codes?
P0171 is fuel TRIM system lean. That means the computer is working to lean the system.
The computer thinks that there is too much fuel in the A/F ratio. Some things to cause it include fuel vapor from the EVAP system dumping into the intake manifold. Have you checked the EVAP purge valve under the hood?
I've never heard of an EVAP so I thank you and I'll check in the morning and respond to you
Old 06-16-2020 | 07:56 AM
  #32
Ron, I understand you bought this 2009 brand new, but that would have been 11 years ago , things wear out.
Old 06-16-2020 | 08:58 AM
  #33
Ron Hanks's Avatar
So true, I don't mind fixing the problem. I'm on a fixed income and can't afford to take to the dealership. I just need to know what to fix. Lol
Old 06-16-2020 | 10:52 AM
  #34
And that’s why I ask so many questions, eventually we’ll get you there.
Old 06-16-2020 | 11:02 AM
  #35
Ron Hanks's Avatar
Thank you for your patience, I'm going to go and check the things that have been suggested within the hour
Old 06-16-2020 | 01:23 PM
  #36
Ok, I’d come over and help you , but the border is still closed, so I’ll kick back and relax , and wait patiently. Oh, next we’ll move on to ground wires! Are they clean and tight!
Old 06-16-2020 | 03:37 PM
  #37
Ron Hanks's Avatar
Went out and checked the EVAP and it's clogged so I had to order it, it will be in Friday I'll put it in as soon as I get it. So sit back and relax and I will get back to you Friday. Thanks for the Help. Lol
Old 06-16-2020 | 04:17 PM
  #38
Cancel your order if you can. The EVAP purge valve(under the hood) is normally closed.
Old 06-16-2020 | 04:47 PM
  #39
Ron Hanks's Avatar
Thanks I'll try to cancel and try other things. I'll keep you posted
Old 06-16-2020 | 04:59 PM
  #40
Check the tube from it to the manifold. And the seals (tube) on both sides.
I know you replaced the fuel pump, have you checked the pressure?
Quick Reply: Need heip
