Need some help w/the ac not working properly!
Old 08-14-2012, 11:42 AM
HHR_KY's Avatar
THIS part did fix MY issue. 15 mintues of work and haven't had the problem return.
Originally Posted by HHR_KY
For what it's worth, perhaps it is the Blend Door Actuator
http://www.autozone.com/autozone/par...uestid=2475716
http://www.autozone.com/autozone/rep...96b43f80cb2dda
I may order and see if this fixes my problem if all other recommended ideas fail to fix my issue.
Found it cheaper here:
http://www.rockauto.com/catalog/rafr...parttype=10721
HHR_KY is offline
Old 08-09-2013, 10:16 AM
smate's Avatar
Hi, glad your problem was solved. Did you find an easy way to get to the blend door actuator and didn't have to take the entire instrument panel retainer out? Or did you change the temperature valve actuator which is easily accessible under the driver side kick panel?(15 minutes work sounds more like the temp.v. actuator rather than the blend door act.)
smate is offline
Old 08-09-2013, 01:24 PM
db/sb's Avatar
Looking at HHR_KY's profile, apparently that post, almost one year ago, was his last activity on this site
db/sb is offline
Old 08-09-2013, 08:54 PM
alexrckid's Avatar
Originally Posted by kvnmccar
What brand did You buy Oneton? I bought a Micro guard from O'reillys for around 12 bucks and it was pure white.
at walmart, pulled a fram CAF out of the box.....it was black tinged...sez carbon impregnated.............also, bout 25 bucks...yikes. bought my purolater CAF bor bout 1/2 that price from autozone...works fine.
alexrckid is offline
Old 08-09-2013, 11:08 PM
jay loukakis's Avatar
I have always heard that the Air both at home and in the car even in the Winter they should be run for a few minutes to keep them working well. So I have always done that and n problums.
jay loukakis is offline
Old 09-03-2013, 06:39 PM
  #26
dsoss50's Avatar
AC Clutch only works on Max
Have been reading so of the answers to peoples problems with HHR. This site is great and glad I joined for future reference.
dsoss50 is offline
jmc2009
06-11-2015 12:30 PM
JCJSS
11-03-2013 06:21 PM
FrugalAudio
10-26-2012 06:46 AM
hhrumadbruh
04-23-2012 04:28 PM
turbotim
12-31-2008 04:27 PM
Quick Reply: Need some help w/the ac not working properly!
