Need tech help, crash damage, no start
I'm working on an 2007 HHR that was hit in the front left corner. The front plug connecter on the transaxel was pushed into the trans., and some wires were cut on the plug harness outside. No other apparent damage to to wiring harness, fuse box or engine.
All looks good on DIC in run position. No indication of start lockout. In start position - No turnover, no fuel pressure, all dash lights and indicators go out.
Bypassed start relay in run pos. - eng. cranks, but no start. All fuses ck good.
My question is if there is posible damage in the trans. to the wiring of the front conn., would that cause a no start on the eng. and can the internal conn. be pulled out to ck for damage or do we need to tear the trans. apart to ck.
And should the eng. be able to start with this plug disconnected?
This is way too much fun.
Thanks for you time.
Kicn
Kicn
What's a FSM thingy? lol
I hav'nt had the codes read, but as in a case of a cut wire somewhere in the harness on pass wrecked vehicals I've worked on, reading codes never helped much unless it was an security issue - bad key chip, or module, ect;. They have never been able to pinpoint a cut wire with codes.
This maybe diffrent
Where I live, no shops have to diag. equipment for a 2007. I would have to haul it 80 mi. to a dealer to get the codes read. lol
Way too much fun.
This maybe diffrent
Way too much fun.
FSM = Factory Service Manual. Maybe the shop that's 80 miles away has one.
I really hope this is your personal vehicle and not a customer's car. If you run the codes, the computer will have the codes stored for the last no-start condition and it should tell you exactly where to start looking for a malfunctioning part.
Also, the transmission will not function without computer control. Fix the harness and connector.
Kicn
Kicn
HHR - No crank/no start after battery disconnect or battery failure.
Reprogram keys into Theft Deterrent Module
Don't replace module, ignition lock cylinder, ECM or BCM
Reference Information/Bulletin 06-06-04-058
Better check with Mr. Goodwrench.
Good luck.
Don't pull on the "pin frame" (outer rim edge of the exposed harness) because they will come out of the harness. If that happens, replacing the harness is a major rebuild requiring removal of trans from the car and a tear down to the sprocket face.
Clare
STREET STYLIN' HHR
12-25-2007 11:51 PM
