Needing Assistance (DTC P0016)
Have a 2009 HHR, 3 days ago it started running sluggish, wouldn't accelerate properly but had no problems starting. Check engine light came on, Code P10016 came up, I changed out both crankshaft and camshaft sensors and the engine light and same code are still coming on. Have no idea what could be the issue, any help would be greatly appreciated.
If it is P0016 why did you change the sensors? It does not indicate bad sensors, just that the sensors don't agree with each other. This is where the mileage comes into play, you may be lucky and only need a tensioner most likely you need a new timing chain and guides.
Here is a link: P0016 Crankshaft Camshaft Position Correlation DTC
