New Battery
I would think WalMart could answer that question better than anyone on this site. But I can tell you, as of about 3 months ago, WalMart did not carry a direct replacement for the HHR (at least in the MAX series).
If you do order online - just read the specification.
if you make a purchase in the store - just see the left side of the battery, the battery has a vent hole there.
But s top all - expert consultation.
I just bought a red top optima battery from summit racing, top post it was actually for an Aveo. 750 cranking amps instead of the stock 600 amps, It was only $30.00 more than the AC Declo battery. The battery cables fit fine, and I was able to use both battery hold downs
I stand corrected !!!
As of 1/6/2013, MY WalMart (Johnson Control) now stocks their Max battery replacement for the HHR.
Their in house number is T5 and it is vented. .........$106 and change.
