New Battery
Old 12-17-2012 | 11:54 AM
gsl54's Avatar
New Battery
Is the WalMart Max 47 Battery vented?
Old 12-17-2012 | 12:10 PM
Snoopy's Avatar
I would think WalMart could answer that question better than anyone on this site. But I can tell you, as of about 3 months ago, WalMart did not carry a direct replacement for the HHR (at least in the MAX series).
Old 12-17-2012 | 06:14 PM
series 90, I believe is the correct one. And Walmart did not carry it last month anyway.
Old 12-17-2012 | 06:15 PM
go with the GM delco battery , for correct size and voltage for the computer system
Old 12-17-2012 | 07:27 PM
I think you mean amperage instead of voltage.
Old 12-17-2012 | 10:05 PM
geg's Avatar
geg
If you do order online - just read the specification.
if you make a purchase in the store - just see the left side of the battery, the battery has a vent hole there.
But s top all - expert consultation.
Old 01-07-2013 | 06:34 PM
Black Box's Avatar
I just bought a red top optima battery from summit racing, top post it was actually for an Aveo. 750 cranking amps instead of the stock 600 amps, It was only $30.00 more than the AC Declo battery. The battery cables fit fine, and I was able to use both battery hold downs
Old 01-07-2013 | 06:43 PM
Ron S's Avatar
Black Box What about the vent?
Old 01-07-2013 | 07:22 PM
Snoopy's Avatar
I stand corrected !!!
As of 1/6/2013, MY WalMart (Johnson Control) now stocks their Max battery replacement for the HHR.
Their in house number is T5 and it is vented. .........$106 and change.
Old 01-07-2013 | 07:59 PM
Glad I ge a deal from Car Quest jut got the replacement for 78.00....
Quick Reply: New Battery
