new blower motor not working
Old 07-18-2020 | 07:57 AM
  #31
HVAC control panel failed.
Old 07-18-2020 | 08:50 AM
  #32
Originally Posted by Kris Gray
If I may...Id like to bring this thread back. 06 HHR. Blower motor replaced,resistor replaced,relay tested with a known working relay,13.60v to the blower motor plug,continuity to the ground,all known fuses that have anything thing to do with the hvac system and the bcm3 fuse...all good. Still no blower motor blowing! Help!!
Did you test the new motor? They have been known to be bad in the box.
The switch has been known to fail.
Old 07-18-2020 | 04:28 PM
  #33
Kris Gray's Avatar
When they bring the car back I can test the fan easy but how would I go about testing the control panel?
Old 07-18-2020 | 05:34 PM
  #34
The fan switch is a simple multi-position rotary switch. It chooses the path to ground via the resistor pack. I would check it for continuity.
Old 09-20-2020 | 08:35 PM
  #35
riereed's Avatar
I am also running into this problem. I have a 2010 HHR. My heat/AC stopped working last year... Trying to get it fixed so I don't have to go through another NY winter with no heat, especially since I have a baby. Today we replaced the blower motor (checked before install, it works), the relay, checked all the fuses (all good, including the BCM3), and checked the switch for functionality as well. Still have no power to the blower. It does not even work on high, so I don't think it is the resistor? I don't have an issue with leaks, everything is clean and dry. What am I missing?!
Old 09-20-2020 | 09:38 PM
  #36
You haven’t replaced the resistor, but you changed everything else, and the HVAC still isn’t working, logic indicates then the resistor is the problem.
Old 09-20-2020 | 09:52 PM
  #37
riereed's Avatar
Thank you. I will check that next.
Old 09-20-2020 | 10:42 PM
  #38
Assuming you mean fuse #4 on the under hood fuse box and relay #30 on the BCM have been tested good there must be a broken wire.
You are correct that if the resistor is bad you would have high fan only, not no fan. It might be pulled out.
However, what do you mean
? The AC compressor will not run if the fan is not on.
fatguy_lilhhr
06-06-2019 03:08 PM
Andrea Lopez
03-27-2017 06:43 AM
Keenan2789
01-23-2016 06:54 PM
Chad Skroch
09-09-2014 05:25 PM
cmp4001
11-30-2010 12:21 PM
Quick Reply: new blower motor not working
