New knocking from front driver's side wheel when braking
I've had my 2009 HHR for nearly a year now. I've been working through the front suspension for knocking/rattling noises and I've got a new one. (The main one was the intermediate steering shaft.) When I brake moderately, I'm getting a pop/creaking noise, especially if I hit a bump while braking. Sometimes it's just one pop, other times it's more of a creaking. Probably not great descriptions, but I don't know what else to call it. It only happens when I'm braking. This started happening immediately after replacing the outer tie-rods. It's loud enough that pedestrians look my direction when it happens.
In troubleshooting the issues I've had I have replaced the following:
What would you recommend I check next? I've looked through the threads on the suspension issues and nothing quite seems to match. But I probably missed something. Thanks in advance as always!
- Outer tie-rods
- Struts
- Intermediate steering shaft
- Sway bar bushing
- Sway bar connecting rods
- Driver side wheel hub (bad sensor)
Good list. Are there any good pictures of the bushings? Maybe I don't know what I'm looking for there.
Just realized I never updated this. So far I haven't found the issue. I do think it's something loose, but I've gone through everything on the driver side wheel and re-torqued it to no avail. The reason I think it's something loose is that when it got super hot (100+ during the day, maybe into the low 80's at night) the sounds went away. When it's cooled down the last couple of days the sound is back. Checked the LCAs as shown in the video. There's no play at all. Move the wheel, move the car.
