New Problem.
Old 04-01-2013 | 12:05 PM
  #51
LawDog88's Avatar
Well. Again. New problem. Driving normally and go to accelerate after slowing for a curve and nothing. Stop and put it in first and slowly lift the rpms and not an inch moved. I stop and apply ebrake and put in first gear no add of gas pedal and car doesn't stall. Check the clutch travel and its normal. ~2" for gear changes. Help?????
Old 04-01-2013 | 12:33 PM
  #52
Setting the parking brake and seeing if the clutch will stall the engine is a standard test to see if the clutch is slipping/gone.
You usually do it in 3rd or 4th since those are the gears that a bad clutch will slip the most in, but since you're not getting any power down in first.....its probably clutch time.
You might have a bad slave cylinder, but it sure sounds like a toasted clutch to me.
Old 04-01-2013 | 12:47 PM
  #53
LawDog88's Avatar
Not covered under power train?
Old 04-01-2013 | 11:43 PM
  #54
Not covered under PT warranty.
Kev- Do you smell anything burnt when trying to go ? Like clutch lining.
Does the pedal feel the same depressing it ?
Old 04-02-2013 | 04:20 AM
  #55
LawDog88's Avatar
Pedal depth and travel felt fine, but I did smell a slight hot smell coming from up front.
Old 04-02-2013 | 10:53 PM
  #56
Burnt clutch has a very distinct smell.. You would remember it.
Old 04-03-2013 | 06:08 AM
  #57
True sleeper. But if Kev's car had a pressure plate that collapsed or it just completely failed, there would be no engagement. If so, then no slipping and no burning smell. From his description, it sounds like a pressure plate.( rare. But I've even seen pressure plate bolts sheer off other cars)
Old 04-03-2013 | 07:09 PM
  #58
LawDog88's Avatar
The dealership said it was the clutch and it will be $1,200 for them to fix it. PASS! I will find somewhere else to get it done.
Old 04-03-2013 | 10:27 PM
  #59
Kev. The clutch consists of the clutch disc and pressure plate when you get a clutch replaced. Best to also replace the slave cylinder(it's inside the bell housing of the trans. where the clutch is) and also have the flywheel resurfaced.
Old 04-03-2013 | 10:43 PM
  #60
Fireman- I agree, after re-reading & for it failing quickly. I would lean towards a possible collapsed pressure plate also..
clutch disc
pressure plate
slave cylinder & throw out bearing..
Quick Reply: New Problem.
