no brake lights
I noticed the same thing after I did my tail light modification. 3rd brake light works but tails (all 4 now) don't work, ONLY when the ignition is OFF. Once you turn it on, all is well. Thought that was very strange, but since they work when the car is on, I'm not all that concerned about it. Figured it had something to do with my modification...guess not.
Not sure what the reason for it is, but it's different.
Edit: & on my '08, the 3rd brake light does NOT light without key on or running also..
Go figure...
I just logged in specifically to ask if anyone has noticed that even though all brake lights work when the key is on, only the CHMSL works when the key is off. Did a quick search, and found this thread. I guess it's normal.
Only my CHMSL (3rd brake light) does need the key to be at least on ACC to activate when depressing the brake..
I guess mine is "special"...........LOL
