No crank, no start
Old 01-09-2014 | 05:24 PM
Snoopy's Avatar
Originally Posted by donbrew
I don't understand the logic in replacing parts out of hand, and possibly unrelated. If the battery has not been checked first, you would be wasting money, time and energy. Might as well replace a tire if you don't know what's wrong and get the same result: money down the drain and still won't start.
Your local autoparts store would be able to check your electrical system including battery, alternator and starter. For free.
No mention of any attempts at a jumpstart (following the directions in the Owner Manual).
Donbrew.....can't agree with you more!!! Seems like a lot of people on this forum throw money into parts before using some personal logic.
Old 01-10-2014 | 05:58 PM
ROCKIE's Avatar
Try re-setting computer by a reader or lifting pos. Battery lead for about a minute, this will reset any faults. Car would'nt start, no clicking sounds after trying to remote start, and i had charged the battery, after many attempts to start it i reset computer and away it went!
Old 01-10-2014 | 06:18 PM
CAUTION:::NEVER try a battery disconnect/reset by removing the POS cable first. You're just risking a battery arc or surge problem. Possible electrical damage or worst case a battery explosion.
Disconnect the NEG side at the battery first.
Old 01-10-2014 | 06:22 PM
Oh ROCKIE, you're a person blessed with unusually good luck.
Disconnecting the Positive cable on the battery invites the chance of damaging or destroying electrical components when you reconnect it.
To reset a vehicle's ECM, you should disconnect the Negative battery cable for a minimum of five minutes.
The ONLY time you should disconnect the Positive cable is after you've first disconnected the Negative cable.
Marush
01-16-2015 12:23 AM
mamasmad
07-28-2014 05:34 PM
Snoopy
01-18-2014 10:31 PM
springer.83
12-29-2013 10:59 AM
rendon47
12-26-2013 07:00 PM
Quick Reply: No crank, no start
