No crank no start
Old 03-04-2020 | 09:16 PM
Pamelalynnhunt's Avatar
No crank no start
My 2006 HHR battery was dead due to key being left on. Had to put another random battery in to start it and while it was running put it's original battery in it and took off for work. Got to work killed it and tried to restart it and I got nothing. Bought a new battery and still nothing, tested starter and it is good. Where do I go next?
Old 03-05-2020 | 08:19 AM
Check the fuse near the battery, if you disconnected the battery while it was running, that might have caused electrical problems, especially if the positive cable touched to ground.
Old 03-05-2020 | 08:38 AM
Cat Man HHR's Avatar
" tested starter and it is good. "
How was this done when you have a no crank condition ?
No start means engine spins over but won't run.
Old 03-05-2020 | 07:24 PM
No crank no start
I took the starter off the car and benched tested it. Everything seemed to work fine. Put it back on and the same thing. Turn key and nothing.
Old 03-05-2020 | 07:41 PM
OshawaHHRss's Avatar
Are you reading rpm?
Old 03-05-2020 | 08:32 PM
There's no RPM, it won't crank...
Old 03-05-2020 | 09:12 PM
Red wire from the fuse box to the starter tight?
that little wire in tight from the ignition switch
https://www.chevyhhr.net/forums/prob...o-crank-56962/
Old 03-06-2020 | 02:20 AM
geg's Avatar
geg
Originally Posted by Oldblue
Check the fuse near the battery, ...
my 5 cents to what has already been said ...
a dead fuse near the battery can kill all surrounding electroconsumers:
First, the diode bridge of the generator.
Then, when the diol bridge is destroyed, uncorrected electricity will kill all the chips.
Be careful and prudent.
Old 03-06-2020 | 09:26 AM
No crank no start
I will check the fuse again, how do I check it with a multi meter? I will also check the red wire, I did notice that the small post where the wire connects to the solenoid is loose, could that be the problem?
Old 03-06-2020 | 09:39 AM
Yes loose wires are a definite problem. Here a tutorial on fuses
