NO Cruise control, remote start or autolock...all quit at once
Old 11-17-2011, 05:22 PM
tonykof's Avatar
There has to be some relevance to this...this must have happened to someone else...??
These all quit at once...No cruise, no remote start, no autolock/when you put it in gear. when you press the remote start (yes, I know how to use it) it clicks under the hood & then is sounds like something else comes un but it does not kick in & turn the motor over...
tonykof is offline
Old 11-17-2011, 06:12 PM
the_shmoo's Avatar
Try re-booting the BCM/ECM by disconnecting the battery for approx. 30 min. Had the same problem, worked for me. Hope this helps.
the_shmoo is offline
Old 11-18-2011, 09:29 AM
tonykof's Avatar
Awesome, thanks I'll give it a try
tonykof is offline
Old 11-21-2011, 03:53 PM
novadude's Avatar
Ok, I had the same experience today, cruise not working, door locks not locking when shifting out of park.. 07 HHR 2LT 68K miles,, already tried disconnecting neg battery terminal, nothing changed. Maybe I need to leave it disconnected longer, only had it off for about 10 min.
Ok, UPDATE,
I went back and disconnected the neg term on battery for about an hour,
connected it back and voila, all is fixed.
WTF? what kind of weird electronics is that?
novadude is offline
Old 11-22-2011, 08:52 AM
tonykof,
Have you taken this issue to the dealer? Let us know how everything works out. Thank you.
Evan, Chevrolet Customer Service
ChevroletCustomerService is offline
Old 11-22-2011, 12:30 PM
the_shmoo's Avatar
novadude, Glad it all worked out for you.
Old 11-23-2011, 07:08 PM
RedWolves's Avatar
Any other helpful hints here? I am going to try to do the unplug battery tomorrow morning. Is there a part that needs to be replaced or something.
This started happening to me this morning.
* No auto start
* no Cruise
* No brake lights
* clicking in shifter box when brakes pressed
* power locks not working when shifter is put into place or in drive.
RedWolves is offline
Old 11-25-2011, 07:34 AM
RedWolves,
I'm sorry to hear you've been having these problems. Have you taken your vehicle to the dealer for any of these problems? Let us know, thank you!
* No auto start
* no Cruise
* No brake lights
Old 11-25-2011, 05:13 PM
RedWolves's Avatar
Just to circle back ... I tried the rebooting the car method above (disconnect the battery and let it sit a few hours) and that solved all the issues. Thanks the_shmoo!
Old 11-26-2011, 12:19 AM
the_shmoo's Avatar
You are welcome RedWolves, glad it worked for you also.
Quick Reply: NO Cruise control, remote start or autolock...all quit at once
