No FOB, but need to lock tail gate/trunk
FOB is busted-daughter is using this car only for a short time before she trades in SO want to save money and not replace FOB. Have figured out how to manually lock everything except the trunk to prevent the beeping that occurs if you use the lock/unlock button. Tried using the lock/unlock button to lock trunk-that works until door is opened. Thoughts? TY
Ok, thanks for confirming it doesn’t help your situation, that’s going to help someone later on.
The last time my remote battery died, I used the interior switch, the closed the door, then when I opened it with the key, the alarm sounded, a PITA.
I soldered they battery cage , cleaned the contacts and put in a new 2032 button battery, that fixed my issue.
Thanks for the replies :)
