No High beams
Old 03-22-2015, 04:11 PM
redheadedshanny's Avatar
No High beams
Hello and thank you for viewing this thread.
I have a 2008 Chevy HHR 2.2 automatic that hasn't had high beams since I bought the car and my wife has said fix it so my response is yes dear.
Here are the things that I have done from reading other threads and need to know if it is a dealer fix or something I can try next.
I have replaced the head lights still no high beams.
I have replaced the main fuse box under the hood still no high beams.
Here is the condition.
Running lights yes.
head lights yes.
pull the multi-switch to you still have head lights, but no addition of the high beams.
push the multi-switch darkness.
blue high beam symbol on the dash lights up.
What do I test/replace next or just bend over for the stealership?
Anything is appreciated. Thank you!
redheadedshanny is offline
Old 03-22-2015, 04:23 PM
Did you replace the relays?
IF you have fog lights, the highbeams will not function when the fogs are on. It's a law.
There is a link that may be of interest in my sig.
donbrew is offline
Old 03-22-2015, 04:40 PM
Welcome to the site, try what Don said and post back your results!
Oldblue is offline
Old 03-22-2015, 07:05 PM
yes and then no.
Tried replacing and switching relays still no go.
Old 03-23-2015, 08:20 AM
Then what about the fogs light suggestion?
Oldblue is offline
Old 03-23-2015, 08:24 AM
Yip and no
I knew I forgot that...
No fog lights.
Old 03-23-2015, 08:57 AM
Correct bulbs?
donbrew is offline
Old 03-23-2015, 09:07 AM
I believe so, but just for giggles what bulbs should be in there?
Old 03-23-2015, 09:13 AM
H13's
Oldblue is offline
Old 03-23-2015, 09:15 AM
Yes, correct bulbs.
Quick Reply: No High beams
