no power2006 HHR
Old 10-03-2020 | 07:54 PM
hotmess209's Avatar
Originally Posted by Oldblue
Fingers crossed!
It didn't change anything. Still wont start. I get power. But when I turn the key I get NOTHING.
Old 10-03-2020 | 07:59 PM
hotmess209's Avatar
And for my defense on my errors, There is no cover over the posts under the hood. I bought the car used. AND WHY would ANYONE have 2 post things under the hood where 1 is red and the other is black...... So my assumptions got me where I am now.
Old 10-03-2020 | 10:20 PM
The fuse at the battery only powers the BCM. To get a ful lobotomy disconnect the negative battery post.
If the power steering fuse did not blow there is no telling what could be damaged.
In later years they added a large red decal on the top of the fuse box illustrating the proper jump points. People still do it wrong, you are not the 5,000.
Old 10-13-2020 | 05:31 PM
hotmess209's Avatar
stressed out. fed up.
still nothing when trying to start.
Only Half Of My fuses Getting power. service air bag light is on. says the brake is set but it is Not. ABS light is on. and still it when i try to turn it over i get nothing.
Old 10-13-2020 | 05:35 PM
hotmess209's Avatar
and trying to use a code reader is useless as no power there either.
Old 10-13-2020 | 06:42 PM
Here’s a how to to inspect the underhood fuse box , it could be the source of your headaches
https://www.chevyhhr.net/forums/www....ad.php?t=59520
Old 10-13-2020 | 09:06 PM
hellshotrod's Avatar
were in cali are u ????
Old 10-13-2020 | 09:52 PM
Looks like about 20 minutes from you.
Old 10-15-2020 | 04:01 PM
hotmess209's Avatar
Modesto
Old 10-15-2020 | 04:31 PM
He is the guy to see for your HHR problems! If you’re that close!
Quick Reply: no power2006 HHR
