No start..!!
Old 10-14-2010 | 09:01 PM
Don06's Avatar
Originally Posted by Sasksurfer
thanks for the suggestion but its really looking like a trip to the dealer, I only hope it is something related to the work they did last week cause its off warranty.
It was under warranty when I had them check the headlight problem but it took them 3 months to get the part and do the work..!!
If it turns out to be the BCM and it was also the cause of the previous headlight problem, it should still be covered under warranty because of when it was first reported.
Old 10-14-2010 | 10:55 PM
Sasksurfer's Avatar
All is well..!!
Thanks for all the suggestions for fixes on my problem.
The panel went on the hook to the dealer this AM and I'm driving it again tonight.
The dealer tells me it was a bad connection in the under hood fuse panel, they took it apart and reassembled it now everything is working.
The bright side ... if there is one ... is that the tow was covered by roadside emergency and the dealer didn't charge me for the fix.
Thanks again to everyone who pitched in.
Old 10-15-2010 | 01:03 PM
Snoopy's Avatar
Ahhh, that sounds like the infamous, TSB on the fuse panel connection.
That was my first thought when reading your post. But you indicated that you had power to the fuse panel. So I disregarded it. Apparrently, the entire connectivity of the panel needs to be checked when this is suspected. That is good to know.
Old 10-15-2010 | 07:31 PM
Sasksurfer's Avatar
The power at the fuse panel fooled me also, but it looks like it was a problem that the signal from the BMC was not getting to the relays where the power was.
Its been 24 hrs and everything is still working..:)
I really hope this was a permanent fix because its going to get real cold real soon here!!!!
The answer makes sense....but why it happened still baffles me
Thanks again everyone
roofer1976
01-04-2014 02:09 PM
spidermanshhr
01-07-2013 09:47 PM
1900colt
10-29-2012 12:01 PM
7734
05-28-2010 01:12 PM
HillsdaleHHR
02-21-2009 02:26 PM
Quick Reply: No start..!!
