Noise very much like a bad wheel bearing
You say you Haven't replaced the control arms yet. Looking at the diagram, it looks like a worn ball joint could possibly allow the 12 to 6 movement you're describing. Maybe it's also causing the geometry to be so wrong that the hub is howling?
Oldblue, thanks for your help.I am hoping Kenny Webster will reply with the solution to his problem..
Of course, you ignored the rest of the sentence. All we have to work with is somebody said they had a noise that sounded like a bad hub. If some particulars had been supplied there may have been help.
"Having this very problem" really says you don't care much. What is the nature of this problem? Just how is your problem exactly like "it sounds like a hub" Did you follow any of the suggestions offered? Kenny Webster will not be back, because he was banned for being obnoxious.
