Normal oil loss?? How much??
Old 05-16-2012 | 11:18 AM
ImNewHere's Avatar
You should see acceptable oil consumption on heavy duty diesel engines if you think that is bad.
Old 05-16-2012 | 08:28 PM
The Owner Manual also clearly states that ANY place between high and low on the dipstick is OK. I just got into a panic recently, I did a oil & filter change 5 Qts oil and the dipstick read 1/2 between H-L after 1K, I had to re-RTFM to calm myself down. It is a range, not a measurement thing. You only need to worry if the dipstick shows less than the low mark, sorry the book is in the car so I can't site the page.
Old 05-16-2012 | 11:12 PM
donbrew-
If I do an overnight cold check, my dipstick reads a tad overfull..
Which I know it is not, but after running it & letting it set 15 mins or so, stick reads perfectly full..
And agree anywhere in the H/L range is acceptable.
Old 05-17-2012 | 06:55 PM
Originally Posted by sleeper
donbrew-
Also, I checked mine with one front tire jacked up enough to remove, oil at the ADD line. The moral of the story is "Don't Panic" unless on level ground your dipstick shows "Less Than Zero" or more than full & growing. I just could not resist some 80's references, "Hitch Hiker's Guide" & Elvis Costello for you "Young Ones" oh no another.
GDZHHR
09-16-2009 08:17 PM
mgfred
09-02-2009 07:50 PM
ecaryn
08-05-2009 12:11 AM
camaro98z28
12-30-2008 10:08 AM
foolmoon_design
10-29-2008 04:35 PM
Quick Reply: Normal oil loss?? How much??
