Not holding fuel pressure....
Old 05-06-2020 | 02:41 PM
It’s in the pump, fuel pressure should be 50 to 60 lbs.
Old 05-07-2020 | 12:20 AM
Mrjustfixit's Avatar
Checked with fuel pressure gauge today and with the fuel pump primed, 3 psi. As soon as the pump stop, pressure drop to o psi in 1 seconds! Takes about 6 or 7 cranks to start and for the first 2 or 3 seconds, the pressure BUILTS up from about 21 psi and tops off at 41 psi in about 5 seconds. So runs rough on first seconds when started but fine afterward. So ordering the AC delco from rockauto Fri.
Old 05-07-2020 | 12:24 AM
Oh yeah... After driving, pressure is 50psi but when shut off pressure drop to o psi in about 15 seconds.
Old 05-07-2020 | 06:10 AM
Thanks for the follow up, yes the fuel pump is done.
Ijazzu
05-05-2015 01:29 PM
Fievel4
Fuel Economy - Hypermiling
01-05-2015 03:42 PM
car nut
12-03-2013 06:32 PM
crresind
02-13-2013 11:46 AM
Jfidelh
10-09-2012 06:14 AM
Quick Reply: Not holding fuel pressure....
