Not a problem.. yet
Old 09-16-2020 | 07:24 AM
letterman7's Avatar
Not a problem.. yet
Just started noticing this as the nights are drawing a little cooler finally. When I go to start the car in the morning, it takes a bit longer for it to actually catch and start. In the summer, the starter might crank once and the motor would light. Now it seems it'll take 4-5 revolutions before it catches. But it catches every time. New(er) battery from last year. I don't remember if it did this last year in the fall/winter or not. Probably nothing, just cooler weather.. still, wanted to see opinions.
Rick
Old 09-16-2020 | 07:56 AM
Cooler more moisture dense air, I suggest you inspect the air filter, and the throttle body.
Old 09-16-2020 | 08:41 AM
letterman7's Avatar
Fresh air filter... I'll check the TB - what am I looking for? Condensation?
Old 09-16-2020 | 09:22 AM
Check the fuel pressure.
Old 09-16-2020 | 09:23 AM
No , oil residue , do not move the throttle plate manually !
https://www.chevyhhr.net/forums/www....ad.php?t=62950
Old 09-16-2020 | 09:50 AM
letterman7's Avatar
Ah, ok. It's going in for inspection next week - I'll make sure the mechanic and I go through those steps.
Marc Guay
02-16-2020 02:38 PM
09hhrproblems
11-16-2017 11:06 AM
Paquinr89
07-06-2016 04:47 PM
jm9678
01-10-2014 06:22 PM
Roughhouse
01-08-2014 01:52 PM
Quick Reply: Not a problem.. yet
