OBD Codes P0575, P0700 & U0073 on 2006 2LT
i will say i had a 08 2lt that had the same kinda probs u say yours does it would run great at times then the gauges would go crazy the driver info would say every thing is bad and i did every thing i could as to what others said , i finaly had a gm tec look it over and he found the abs Brian was shorting out and driving the electric system crazy as soon as i change it all the probs went away and we reflashed the brain to my vin and the abs light and trac control all work again my buddy has had it now for over a year with no probs now , again just my 2 cents as i have another one now with a bad abs Brian
C0550 means there is an internal fault in one the control modules. Oldblue's glasses are malfunctioning again, he sees c0050.
U0073 means something similar.
All of the others are related to that.
It may be that the ECM connectors are fouled up, we have heard similar stories solved by cleaning them and stopping oil migration creeping up the harness.
The cobalt link that oldblue provided is for c0550. But it's a very short thread. There's a "related thread" that immediately follows it, that the fix was new hubs. Maybe not so closely related, maybe more like a step brother"s in-laws.
The Mitchell on Demand post, is vague at best.
Alrighty then, I reread the last post#6 , and the rest of that link , nothing mentioned about P0050, so fine, could be a bum steer in that thread,carry on, I’m out.
I only posted a bit of the Mitchell article. The point being it could be any of the modules and further testing is needed to find which one. And figuring out what exactly is the cause of the checksum error, which is one of those "scary computer" things.
