Oil & Coolant leak
Old 09-11-2019, 02:33 PM
mobilebyrd's Avatar
Originally Posted by donbrew
You will probably want to get the chain cover gaskets too, They are paper thin.
Donbrew, please correct me if I'm mistaken...
To replace the seal behind the harmonic balancer one would only need the front crank seal (356), bolt & washer (428 & 429)...correct?
Please advise if additional items are needed/advised.
I intend to rent the harmonic balancer lockout tool for free from a local auto-parts store.
Also, thank you to everyone for their help and input thus far and in the future.
This is a truly fantastic forum.
File Type: pdf
File Type: pdf
mobilebyrd is offline
Old 09-11-2019, 03:17 PM
You're right, if that's all you need.
donbrew is offline
Old 09-11-2019, 07:02 PM
I told about that oil slinging. The seal can be replaced with the front cover in place.
Oldblue is offline
Old 09-11-2019, 08:30 PM
mobilebyrd's Avatar
Yup. Once I pulled all that plastic out of the way it was easy to identify.
I've since cleaned the area up and am driving it a bit with the fender liner off to see where any new leakage can be spotted.
A new driver, tensioner, bolt, and seal have arrived and I'm looking for a rental tool to hold the balancer in place. If I can't find one, I might just buy one for $60 and resell it.
Old 09-11-2019, 08:31 PM
But not for to long , get it fixed .
Oldblue is offline
Old 09-11-2019, 08:34 PM
  #26
mobilebyrd's Avatar
If I can find the tool I'll have it fixed before the weekend. If not, I'll fix it next week. It might get 100 miles on it, tops, before getting fixed.
I left the plastic panel of so I can monitor it closely.
Old 09-11-2019, 08:41 PM
  #27
What tool?
Oldblue is offline
Old 09-11-2019, 09:31 PM
  #28
mobilebyrd's Avatar
What tool?
I don't have good luck and it's my daily driver so I'll wait for the tool.
Old 09-12-2019, 09:22 AM
  #29
Please post a picture of the tool when you get it.
Oldblue is offline
Old 09-12-2019, 10:37 AM
  #30
Probably the spanner.
RJ_RS_SS_350 is offline
Quick Reply: Oil & Coolant leak
