Oil & Coolant leak
Old 09-12-2019, 12:36 PM
  #31
This tool?
Oldblue is offline
Old 09-13-2019, 12:17 PM
  #32
mobilebyrd's Avatar
I can't get the bolt out.
I've tried both 18" and 24" breaker bar and even a 1/2" electric Ridgid impact gun (manual says 2,250 in lb)
The bolt won't budge and I'm applying enough force with a breaker bar that I'm moving the engine and am concerned the pry bar wedged in the balancer will bend or let loose.
mobilebyrd is offline
Old 09-13-2019, 03:11 PM
  #33
The torque wrench isn’t the tool to use as a breaker bar.
I used my 1/2 drive 24 “ breaker bar and the handle from my HF aluminum jack for an extension of leverage
Oldblue is offline
Old 09-13-2019, 04:25 PM
  #34
My cheap HF air gun did mine.
The spec is 74 ft. lb. + 125 degrees. that translates to something like 180 ft. lb.
I guess that means that it has been off before and replaced by King Kong.
donbrew is offline
Old 09-13-2019, 04:40 PM
  #35
Definitely replace that crank pulley bolt.
Oldblue is offline
Old 09-13-2019, 04:47 PM
  #36
Blue_SS's Avatar
This is great advice. Once you get it out...
Blue_SS is offline
Old 09-13-2019, 04:51 PM
  #37
Blue_SS's Avatar
OP, if it's an auto, make sure it's in Park. Manuals should be in 5th gear (and wheels loaded if you can).
Both increase the engine's resistance to just turn, and should help you loosen it...
Blue_SS is offline
Old 09-13-2019, 06:37 PM
  #38
mobilebyrd's Avatar
I I only use the torque wrench to confirm that 125 foot pounds wouldn't break the bolt free.
I have a new bolt, washer, & seal but can't get that bolt off.
Old 09-13-2019, 06:38 PM
  #39
mobilebyrd's Avatar
Thanks.
It's an automatic and was in park.
Old 09-13-2019, 06:59 PM
  #40
You need a better impact gun. Trying to turn against the bolt with just a wrench is only going to allow the crankshaft to turn before it breaks loose. The impact gun has the advantage of "rattling" it loose so to speak.
Learned this lesson the hard way on several things over the years. Tried to take some blades off a bush hog deck one time. 1 1/4 nut wouldn't budge with a 4 ft cheater bar. Impact gun with 150 psi behind it got it off.
firemangeorge is offline
Quick Reply: Oil & Coolant leak
