Oil Cooler
Old 01-21-2011 | 09:54 PM
Andyman's Avatar
Oil Cooler
Haas anyone installed an oil cooler in an early 2006 HHR 2.4 LT. Chev. had oil coolers in the first 6 months or so of the HHR and later did away with them. Oil leaking need to replace? Repair? Seals? Any Advice or help.....Thanks
Old 01-21-2011 | 10:19 PM
IgottaWoody's Avatar
Hmm...first I heaRD that.....
Old 01-21-2011 | 10:22 PM
Doctuh's Avatar
Really?
Girlfriend just got an 06 - where is the old cooler and what did they do to replace it - just decide that the oil was cooled with the engine coolant? Does anyone have pictures of with and without to show where this part might or might not be?
Old 01-22-2011 | 01:06 AM
Andyman- Welcome...
Carryover Features & Benefits from 2007 model year
Eliminate External Oil Cooler
The Ecotec 2.4L I4 VVT is no longer fitted w/external oil cooler. Validation tests have demonstrated that, w/durability enhancing features such as increased coolant capacity & targeted oil jets that cool the underside of the pistons, the oil cooler is not required even during extreme operating conditions.
Source: https://www.chevyhhr.net/forums/2-4l-performance-tech-14/2-4-tech-write-up-22490/
Old 01-22-2011 | 04:31 AM
Andyman's Avatar
'06 Oil Cooler Location
The early production models of the HHR had oil coolers located to the top right of the motor right beside the oil filter area. Apparently mid 2006 production Chev did away with the oil coolers so this is why you may not have heard or seen them. I purchased my vehicle in June of '05 and was the 3rd HHR ever made. A smallgroup of HHR's were released in late June as an introduction before general production began. I love this car and this is the first thing that has gone bad after 75K and app. 5.5 years old so I have no complaints. Looking for any advice because I need to replace asap as the cooler is leaking badly. I am going to attempt this weekend. Doesn't look like to big of an ordeal the wiring harness that encircles it's location I believe is going to be more of a hassle than actually replacing. Part goes for $300 with GM discount app $170. Shop wanted $470 to do the job so I figured I might have to take a shot at this myself. Thanks for any help/advice. Love this site. If I could upload a picture of location I would but can't figure out how to do......
Old 01-22-2011 | 12:15 PM
Lucky's Avatar
I wonder if you can just remove it. someone at gm must have decided that the cooler was not needed. (might be cheeper)
Old 01-23-2011 | 12:47 AM
Andyman-
Not having a clue to it's look, size or even if it's hard line connected, why not use a universal type for low cost & hook up with hose & clamps ?
Just a thought..
Old 01-23-2011 | 01:18 AM
Andyman's Avatar
I was able to post a picture of Oil Cooler and it's location in the Gallery under Member's HHR's titled '06 Oil Cooler. The link below should bring it up ?????? Don't know how to get the pic in this message???
https://www.chevyhhr.net/gallery/fil...erLocation.JPG
Old 01-23-2011 | 01:19 AM
Andyman's Avatar
sleeper...... thanks for the info I am looking into that now. I finally got a picture uploaded.....see earlier message with link. THANKS
Old 01-23-2011 | 01:26 AM
Early '06 Oil Cooler
Andyman-
It looks more like a "heat-sink" type, than a radiator style (air flow thru) cooler.
Can't see the connections, but posted the pic for ya.
You just right click on it,
then click on "Properties" & copy & paste the URL & add [img] URL goes here w/no spaces [/img] tags, like this.
just a FYI.
