oil filter wrench
Old 12-13-2007, 11:05 PM
pea420's Avatar
Exclamation oil filter wrench
Anyone outhere know part #'s for the different brandwrenches Please Iam knew and some replies can RUFF ! ! !
pea420 is offline
Old 12-13-2007, 11:20 PM
Snoopy's Avatar
A couple of different threads on this already. You might want to use the search function for the different ones. Some discuss additional information/topic.
Snoopy is offline
Old 12-14-2007, 06:11 AM
Peter, as Snoopy already posted, in the search bar just type in Oil Filter Wrench. It will bring up quite a few threads
HillsdaleHHR is offline
Old 12-14-2007, 07:08 AM
Firewatcher's Avatar
Here's a "how to" https://www.chevyhhr.net/forums/show...=filter+wrench
The wrenches themselves are available at most auto parts stores.
Guys, besides the "Search" feature, there is also the "nice factor"
Firewatcher is offline
Old 12-14-2007, 08:54 AM
courthousedeb's Avatar
Good post firewatcher...and besides, if you use the term oil filter wrench, you'll get this response. You'll get some threads, but the search engine does not
The following words are either very common, too long, or too short and were not included in your search: oil
Or this with the term HHR...but I do realize it's a very common word here
Sorry - no matches. Please try some different terms.
The following words are either very common, too long, or too short and were not included in your search : HHR
But if you type in HHRs you get 500 threads. Guess if you make your search term a 4 letter word, you'll get some threads returned on your search.
Most forum search engines leave a little to be desired, so I think rather thantell someone to look for it themselves, why not be helpful? Maybe that's just asking too much.
courthousedeb is offline
Old 12-14-2007, 08:58 AM
I've typed in Oil filter wrench in and recieved 15 threads. Yes you may have to search through them. Pointing someone in the right direction is being helpful My post was not geared toward being mean and I do not think Snoopy's was either. If you have the extra time to search through and find the exact thread then great
Old 12-14-2007, 09:01 AM
JoeR's Avatar
Just get a common socket, either 1-1/4" or 32 mm.
A long extension helps, too.
Geez, ya'll are gonna scare the n00bs away.
JoeR is offline
Old 12-14-2007, 09:02 AM
And if someone knows the exact answer, GREAT!!! Thanks, JoeR
Old 12-14-2007, 09:07 AM
I do believe this newbie is looking for the wrench to remove the oil filter itself and not the socket. He did say WRENCH in the subject...so without further ado I find that google is much more user friendly than ANY forum search engine.
JC Whitney has a bunch of assorted tools for HHR Oil Systems...this should give you all the info that you need.
http://www.jcwhitney.com/Chevrolet-H...-600017979.jcw
Old 12-14-2007, 09:56 AM
an08HHR's Avatar
Welcome to the forum Complete how to change oil click https://www.chevyhhr.net/forums/maintenance-upkeep-50/how-change-your-own-oil-10546/
None of those from JCWhitney will work on a HHR . HHR has a drop in filter not a spin on canister.
an08HHR is offline
Quick Reply: oil filter wrench
