Oil leak
Oil leak
I noticed some drops of fluid on my garage floor under the front bumper. I put a pan under there & (overnight) I caught a couple of of these drips (it's a slow leak).
It is tranny fluid (thin, red fluid). I suspect a rock has damaged my transmission oil cooler.
Am I right?
Anybody else had this happen (yes I'm guessing).
Any ideas on how much I should expect to pay for repairs?
P.S. I have 'the screen' cover over the opening so it must've hit underneath that somewhere (?)
Am I right?
no cooler....could be anything from a loose pan bolt to a pump seal going south.....spray clean the underside and drive it..re inspect for leaks, easier to locate when its clean and fresh oil is present.....keep us informed.....
If a right under the bumper, then flows radiator. Check your antifreeze (look in the expansion tank). If the antifreeze in red, then the probability of damage to the radiator is large.
I had decompression radiator as a result of severe frost.
I sealed. But I suggest you replace the radiator.
Cost:
New radiator $ - 110 - 150
Work on replacing the radiator $ - 20 - 50
new fluid (antifreeze) $ - up to 15.
For the cost of the radiator guarantee. For the cost of works would not answer in different places in different price.
Cost:
Cost:
Tsb
Don't forget that there is a TSB for a shield for that area:
#08-06-02-001: No A/C, Engine Coolant Leak, Engine Overheating (Install
Plastic Shield to Stop Stone/Debris Impingement) - (Feb 13, 2008)
Subject: No A/C, Engine Coolant Leak, Engine Overheating (Install Plastic Shield to Stop Stone/Debris Impingement)
Models: 2006-2007 Chevrolet HHR, LS, LT and Panel Van
Built Prior to August 27, 2007
Condition
Some customers may comment on the engine overheating, a coolant leak, or that the A/C is inoperative.
Cause
This may be due to the very large opening in the front fascia.
Stones/debris can impact the A/C condenser and/or the radiator and
pierce the horizontal cooling tubes. This in turn causes loss of A/C
refrigerant, loss of engine coolant and/or engine overheating.
Correction
Important:: Verify that the customer concern was caused by condenser/radiator impingement.
Important:: Prior to installing the shield, inspect the condenser and the radiator for stone impingement.
Dealer technicians are to install a plastic shield that snaps onto the
condenser vertical tubes that protects the horizontal radiator and
condenser cooling tubes.
Parts Information
Part Number
Description
Qty
25829960
Screen, Radiator Grille
Condition
Cause
Correction
Parts Information
Part Number
Description
Qty
25829960
BTW: GM adds those pellets in every new car..
But please explain to me. you funny, that I sealed my radiator?
