Oil Pan Stuck
Old 04-08-2012 | 08:18 PM
Heritage High Roof's Avatar
Oil Pan Stuck
I had a One of the plastic timing chain guides come apart and I need to take off the oil pan to retrieve at least 2 broken pieces. I have all the bolts out including the 4 transmission mounting bolts and the lower AC compressor bolt and the pan won't budge. I have tried prying on all the "pry points" and hammered on the pan with a dead blow hammer. I even threaded in a large bolt into one of the threaded bosses on the right side of the pan and pushed straight down through the engine compartment with a 40 inch crowbar.
Any ideas?
Old 04-08-2012 | 11:24 PM
Pull up the engine PDF I sent you and go to page 250, the oil pan removal procedure starts there, I don't think you missed any bolts....but the GM sealant might be a heck of a lot stronger than I ever figured.
Old 04-09-2012 | 05:17 AM
Dynamite!!!!!
Old 04-10-2012 | 03:48 PM
I gave up on the oil pan for now. I don't think the pieces will hurt anything.
aeroned
04-01-2012 09:36 AM
hookdriver
08-19-2011 12:53 AM
cruzzonn
10-25-2009 10:34 AM
willow5446
09-10-2008 01:08 PM
JT's HHR
06-29-2007 03:59 PM
Quick Reply: Oil Pan Stuck
