one headlight is a different color... help
Old 02-11-2015 | 07:56 PM
ifknrock09's Avatar
Ok so on my way to work a few weeks ago my co-worker was in front of me and when we got to work he told me that my headlights were a different color. I thought this would be because I had to replace my passenger side bulb the week before. Well I just purchased new HIDs for my headlights and fog lights. After installing them the same side my coworker said was a different color is still different. I double checked the bulbs to make sure they were the same "k". What could be my issue ? I'm leading towards a grounding issue. But idk. Any help is greatly appreciated.
Old 02-11-2015 | 08:19 PM
Danman03's Avatar
What do you mean by different color? What color of bulbs are you using?
Old 02-11-2015 | 08:33 PM
ifknrock09's Avatar
Like my 3k bulb looks like a 4300k or 5k.
Old 02-11-2015 | 08:37 PM
Danman03's Avatar
There could be a couple of things causing this issue. From my understanding, HIDs have a grace period for them to "settle" into their color. I think this is around 100 hours or so. So during that time, the color could fluctuate a bit. Also, it could be your balast going out. I don't think it would make it brighter, but it's a possibility. The last thing I could think of is your angle is off on the bulb. If it's too high or too low, it could cause the color difference.
Old 02-11-2015 | 08:56 PM
ifknrock09's Avatar
I've had HIDs before and they never were this off.
Old 02-11-2015 | 08:59 PM
Danman03's Avatar
Yeah, it's a little odd that there is that much of a difference. And the bulbs are the same color?
Old 02-11-2015 | 09:32 PM
ifknrock09's Avatar
Ya they looked it.
Old 02-11-2015 | 09:45 PM
Danman03's Avatar
I'm just wondering if maybe the manufacturer sent you 2 different colored bulbs. Have you tried switching the bulbs to different sides? I would think that if the bulbs are switched and you have the same problem on the same side, then you know there is something wrong on that side, but if the problem has the problem on the opposite side, then it would have to be the bulb. Make sense?
Old 02-11-2015 | 10:23 PM
black Tara's Avatar
I"m with Dan the man on this one
Old 02-12-2015 | 06:48 AM
Testing testing, time for some testing. You might have to swap the balasts from side to side after you swap bulbs.
Quick Reply: one headlight is a different color... help
