Outside air temperature sensor & wiring
Old 11-10-2013 | 04:19 PM
myers1wa's Avatar
Does anyone know what voltage is at the connector for the ambient air temp sensor. I'm reading about 1.5 volts at the green wire, nothing on the yellow wire.
As far as the sensor itself I'm reading about 1700 ohms resistance between the terminals. Changed sensors still no reading in the dash
Old 11-10-2013 | 04:28 PM
badassbowtie's Avatar
GM says 4.7-5.3 volts... sounds like a short since your voltage is low..But I don't have a diagram to confirm those are the correct colors either..
Edit: GM says if its low(1.5 volts) its a short to ground...
I found all of this info through our google search function
Old 11-10-2013 | 11:26 PM
You would not get a reading on one of the wires. Temp sensors usually (not sure specifically) are a diode that allows a current through that varies by temp. so, you would only get a reading if the diode was in place and then only if you know what you are doing.
I would be asking what happened just before the temp stopped on the dash. It is very rare for a diode to fail spontaneously, more likely something else in the circuit.
Check your PM.
ironheadbro
03-06-2020 08:00 AM
sammyrye
03-01-2015 01:07 AM
djs31763
06-22-2014 06:24 PM
sammyrye
07-11-2010 09:48 PM
dinobass
11-20-2006 03:18 PM
Quick Reply: Outside air temperature sensor & wiring
