P0010 and P0013 codes - can you just clean the solenoids or do they have to be repla?
Old 10-02-2018 | 10:28 AM
Mchowe's Avatar
Thanks for the opportunity to share my car problems; I’ve got a 2011 HHR LT with 125,000+ miles on it and the OBD-11 readout is as follows:
P0010 intake camshaft position actuator circuit / open (bank1)
P0102 mass air flow (maf) sensor circuit low frequency
P0113 intake air temperature (iat) sensor circuit high voltage
P013A H02S slow response rich to lean sensor 2
P0010 intake camshaft position actuator circuit/ open (bank 1)
P0010 intake camshaft position actuator circuit /open (bank 1)
Ive changed the oil, oil filter and air filter, plus installed a new cmp sensor and removed and cleaned the MAF with some specific CRC mass airflow sensor cleaner.
question is, can I simply pull both the intake and exhaust camshaft position actuators (individually) and clean them with the same spray, then reinstall them or should I replace them?
TIA, Michael
Old 10-02-2018 | 10:30 AM
Welcome to the site, you can try that, most times it’s the electrical that fails. So, be ready to order up new ones.
I’m thinking more low voltage at the battery, and or a loose timing chain or broken front guide upper bolt.
Old 10-02-2018 | 10:45 AM
Mchowe's Avatar
Ok,I’m not having any issues with shifting but I did notice a slight drop in mpg which I primarily attributed to the lack of air and oil filter/oil changes.
Old 10-02-2018 | 11:11 AM
The red above is most likely the root of your solenoid codes. Dirty oil has plugged up the solenoids. Don't try and clean them. Get new ones(both) and swap them out. It's a simple 20 minute job.
Old 10-02-2018 | 11:56 AM
Amazon has these
[2 Pcs] Intake + Exhaust Camshaft Position Actuator Solenoids For GM Chevy Malibu HHR Buick Pontiac 2.0L 2.2L 2.4L 12655420 12655421
Amazon Amazon
Old 10-02-2018 | 12:05 PM
aradmahogany's Avatar
Do a fresh oil change when you change the solenoids, too
Old 10-02-2018 | 01:05 PM
Cat Man HHR's Avatar
Dirty oil has plugged up the solenoids..
If you like to play, yeah clean them and see what happens. If it fails install new ones. And yes change the oil more often.
Old 10-02-2018 | 01:23 PM
Why are you only worried about those 2 codes?
Old 10-02-2018 | 02:03 PM
Mchowe's Avatar
Ideally I want to fix all of the ref codes; also when I called the local Chevy dealer parts dept they gave me the new updated p:n’s: 12679100 and 12679099 , but when I checked on amazon and plug in my make, model and year HHR, it says they won’t fit my vehicle? So who’s right???
Old 10-02-2018 | 02:13 PM
Don't always believe Amazon.
Look to Ebay and ask a good seller about the part . More times than not you will find a better price with free shipping.
Quick Reply: P0010 and P0013 codes - can you just clean the solenoids or do they have to be repla?
