P0011 code is back and thats the good news
Good luck on yours..
To update, SLEEPER you were right about bearings but not #3. All four camshaft end bearings are bad. I suspect not enough oil is getting to the top of the engine. But there has to be some sensor that should have detected that.
GM is covering this under the powertrain warrenty. Hope to get the car back by the end of next week.
There is only one oil pressure sensor for the entire system. If one oil gallery gets plugged, that sensor cannot know that some part of the engine is getting starved for oil. Also, low oil level will cause starvation under hard cornering, and it is usually the valve train that gets the worst of it.
I can live with that, its the chance you take for performance.
Good luck on that.. Good you have warranty..
Lastest update. GM approved a new engine and was ordered yesterday. I should get the car back the first part of next week.
I'm on the third rental. The HHR 2.2L, then the Mailbu they gave me took a nail in the tire over the weekend. The latest is an Impala. At the rate I'm going through the Chevy line I may get to try a Camaro by the time I get mine back.
DASH0071972@
23
07-01-2015 12:31 PM
Sno White
10-03-2012 07:05 PM
Wolfn
08-15-2009 08:37 PM
