P0446
Old 04-27-2021 | 07:21 AM
Tbopp's Avatar
Angry P0446
Don. You stated that Mitchell does not list P0455 but the OP, GIJOE1980 said his code was P0445
Not sure if the OP misprinted or his reader was in error.
Anyhow. Pulled this short list from one of ChevyMgr's old threads.(no P0445 here)
P0420 Catalyst System Low Efficiency
P0442 Evaporative Emissions (EVAP) System Small Leak Detected
P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
P0446 Evaporative Emissions (EVAP) Vent System Performance
P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
P0450 Fuel Tank Pressure (FTP) Sensor Circuit
P0451 Fuel Tank Pressure (FTP) Sensor Performance
P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
P0454 Fuel Tank Pressure (FTP) Sensor Circuit Intermittent
P0455 Evaporative Emission (EVAP) System Large Leak
P0458 Evaporative Emission (EVAP) Purge Solenoid Control Circuit Low Voltage
P0459 Evaporative Emission (EVAP) Purge Solenoid Control Circuit High Voltage
I've replace the front solenoid under the hood and also the rear purge valve to no avail. Light is still on. And ideas? Oh also since owning this car and that light being on I can't fill gas into it without the pump shutting off every couple seconds. I have to go in slow half depressed pump lever. Thanks in advance guys
Old 04-27-2021 | 07:43 AM
EVAP canister under the car has a problem, please post the code number so we can further review the causes
Old 04-27-2021 | 07:56 AM
Tbopp's Avatar
Code p0446
Sorry I posted it in the title. It's p0446
Old 04-27-2021 | 08:03 AM
Tbopp's Avatar
More info
Also I don't know if it matters much, but the 3 bolts rusted/ broke off at the cat to tail pipe. So I replaced gasket there and the holes where bolts connect the cat to pipe was rusted/worn/ no existing. So I got 1 of them make your own flange and put it on either side to close them 2 sections together with new gasket. Quieter like new the first month but now has a lil Leake of exaust from there and some noise not to bad.
Old 04-27-2021 | 08:19 AM
Oh, the OP was talking about P0443, that’s the confusion.
P0446 as we see in this description is related to the purge vent valve, a short or wiring problem
https://www.obd-codes.com/p0446
I recommend you test the connector at the purge vent valve , if you recently replaced it what part number did you use? As some replacement valves require a pigtail for the under car valve.
I’ve also had issues with the under hood valve failing, if you can blow air through it , it’s no good.
I see you have a 2011, so if the exhaust flange bolts were rusted , then you might need to remove the exhaust manifold and replace the studs , and the gasket.
is the flex pipe rusted thru also?
Old 04-27-2021 | 08:26 AM
Tbopp's Avatar
More info
Negative on the rust through just at the connection gasket and this s the part I put in which was an exact fit with the connector
Old 04-27-2021 | 08:28 AM
Tbopp's Avatar
It wasn't rusted at the exhaust manifold. It was the 2 bolts connection and flange from the cat side of pipe to the rear pipe in the middle of the car
Old 04-27-2021 | 08:33 AM
Tbopp's Avatar
So the right side of this pic with the 2 holes and flange. holes rotten through so I used somthing like the 2nd picture to close it back up for now
Old 04-27-2021 | 08:47 AM
Ok, then check the harness side of the wiring.
Old 04-27-2021 | 08:51 AM
Tbopp's Avatar
I will check that, is that harness side a short enough wire with connector that I could buy and replace from somewhere? Thank you
Quick Reply: P0446
