P0446
Old 04-27-2021 | 09:14 AM
Test the wires they should be 12 V and ground when engine on. The valve should be open when the ignition is off so that you can fill the tank; that is why it is hard to fill. Like trying to fill a soda pop bottle with a hose and no vent. If the vent is working properly the charcoal canister is suspect.
Old 04-27-2021 | 09:18 AM
Moved to a new thread because it is too confusing to hijak 3 year old threads.
Old 04-27-2021 | 09:24 AM
Some just cut an crimp the pigtail to the original harness if you find a corrosion issue there.
Old 04-27-2021 | 01:42 PM
P0446 means there is an obstruction in the vent system.
A clogged charcoal filter; the media inside the canister.
A bent/kinked vent tube. From the valve to the top of the filler pipe.
A clogged/stuck valve.
A stuck closed purge valve.
A bent/kinked EVAP return pipe.
UnknownError
09-25-2019 05:58 PM
Lambo
11-07-2017 09:30 PM
PulpFriction
03-03-2016 06:09 PM
Greylotus11
06-22-2013 11:20 AM
saturnsw2
08-29-2012 09:00 PM
Quick Reply: P0446
