P0455 cel 2008 ls 2.2
Old 11-14-2016 | 09:58 AM
eclewis's Avatar
I have been trying to solve this one for over a year, with no luck. I car runs fine and driveability has never been an issue. However, outside of being an annoying dash light, I can not pass a Missouri Emissions Inspection with the CEL, and since the tags are 4 months overdue, I'm hoping that someone can help. The following is the list of parts replaced:
fuel cap
fuel tank pressure sensor
vapor canister
purge valve/solenoid
vent valve/solenoid
PCV hose
Thanks,
Justin
Old 11-14-2016 | 10:28 AM
Welcome!
A typical point of failure is the O-ring between the canister and the valve.
Somewhere there is a leak, a tube may be broken or a connection not secured or a valve stuck open.
Old 11-14-2016 | 10:34 AM
Welcome to the site!
X2 on the leak as I'm sure you've read this but I post the link for other interested parties.
Also check for loose wires and ground connections
https://www.obd-codes.com/p0455
Old 11-14-2016 | 10:37 AM
eclewis's Avatar
Thanks. I'll check that. I remember when I changed the vapor canister, that one on the lines into the canister did not fit very well with a supplied rubber grommet. I believe that I removed it, but I know I kept it. I'll double-check to verify that is what I did, and install if that is the case.
Old 11-14-2016 | 10:44 AM
Some have reported using 2 O-rings worked.
CDS31MC
03-24-2023 09:00 PM
LadyBee
06-20-2014 11:48 AM
jwjones
11-20-2013 07:22 AM
asanti
05-24-2012 07:47 PM
jonboyb
04-08-2008 12:08 AM
Quick Reply: P0455 cel 2008 ls 2.2
